So i got in my car this morning.. about 30 degrees btw. and the heater did not turn on. i tried turning it off and back on..... and still doesnt work and i cant drive it because the window keeps fogging up on me. I bet its the fuse but i am betting someone else has had this same problem! HELP ME OUT! GRACIAS BROS
Heater Stopped Working! Help!
does it blow when you turn air on?
the problem is not your heater but the blower motor. I know it sounds like a stupid thing to correct you on but this will help you get more assistance, pin pointing the actual problem and not a broad generalization. It's not that you aren't getting heat you see, it's that you aren't getting air flow.
I know, I know...but remember we aren't in the car with you and we don't know what you mean...we only know exactly what you say, and can't infer what you meant. The more info you give the better we can help.
anyway as mentioned, check your fuse...let us know after checking that.Last edited by bcjammerx; 02-23-2010, 03:37 PM.____
Originally posted by bcjammerx View Postthe problem is not your heater but the blower motor. I know it sounds like a stupid thing to correct you on but this will help you get more assistance, pin pointing the actual problem and not a broad generalization. It's not that you aren't getting heat you see, it's that you aren't getting air flow.
Mine jus went out a few weeks ago and i replaced it, try knockin up under the passenger side dash if it comes on then the motors going out. If it comes on u can do that 4 alil while but how long is unknown. its not hard to replace but it does take alil finesse to get the box out. I suggest lookin online 4 a new motor autozone and advane want 100+ for jus the motor 130+ for motor and wheels, i found one 50 online.
As already mentioned check the fuse.
If the fuse is OK, its more than likely the heater resistor.
My 5.7 LS1 Holden Ute
Originally posted by ben_cb7 View Postfuse was ok. so i need to replace the heater unit?
Originally posted by vietkid_2006 View PostYes you will need to replace your blower motor. it's under the dash.
Firstly check for power at the motor:
If there is no power at the motor, check the Heater resistor.
If there Is power at the motor, then the motor is faulty.
Originally posted by evil_demon_01 View PostNo not the actual motor, the motor resistor (speed controller) in the heater box.
If there Is power at the motor, then the motor is faulty.Last edited by ben_cb7; 02-23-2010, 07:51 PM.
