okay so at the moment i am in the process of getting ready for a swap on my 92 ex. i want to make the car run as smooth as i can so i am going to put a h22a in it along with a lsd. i am choosing to do this because the f22b that i have is in kinda rough shape and i dont know if it well last me much longer.as for the motor i well be going with hmotorsonline for getting the motor and tranny as the previous company i bought my current motor from isnt very reputable. so far i have a list of things i well be replacing while i do the swap that would be very good to replace to make it as reliable as possible.
1-h22a with lsd tranny (auto)
2-timing belt
3-water pump
4-balance belt
5-thermostat
6-fuel injector o-rings
7-valve cover gasket kit
8-spark plugs
9-oil filter
10-92-96 prelude radiator hoses
11-distributor car and rotor
12-front and rear main seals
13-front balance shaft seal
14-cam plug seal
15-camshaft seal
16-transmission output seals
17-alternator belt
18-o2 sensor
19- megan racing header for h22
20-new axles
2-timing belt
3-water pump
4-balance belt
5-thermostat
8-spark plugs
9-oil filter
14-cam plug seal
15-camshaft seal
17-alternator belt
18-o2 sensor
20-new axles
