alright well my friend did a little mod to my car he took off the cruise control wire and he loosened up a bolt that supposebly gives the acceleration a quicker response , now every time i press down on the accelerator the response is alot quicker , so my question is if does anything bad to the accelerator and what this technique is called ???
Fast Acceleration
Originally posted by gloryaccordy View PostIT's all in your mind bro
Its all in your mind. You think you did somthing to make your car faster and now your looking for it and some times your mind tricks you into beliving it happend. If you floor it you open your throttle up 100% loosening some bolt for cruise control wont let anymore air/fuel get in therfore this mod did nothing.
[QUOTE=Tippey764;2433809]Its all in your mind. You think you did somthing to make your car faster and now your looking for it and some times your mind tricks you into beliving it happend. If you floor it you open your throttle up 100% loosening some bolt for cruise control wont let anymore air/fuel get in therfore this mod did nothing.[/QUO
ok all i know its next to the throttle body and the wire that he took off was the cruise control wire thats connected to the accelerator wire plate or whatever its called and now everytime i step on the accelerator i barely have to tap it or else ill haul ass lol
Originally posted by accordkid16 View Posti just said what it was he set your idle higher thats it
hahaha alright and for the cruise control wire thats loose now whats that suppose to do ???
sounds like he just tightened the throttle cable. As in he tightened it too much so its constantly applying slight throttle causing it to idle higher. You didnt gain anything.... you just have to press the peddle down "less" to open the throttle the same amount because its already being held open by the over tightenede cable.
Thats my theory. accept it or notOriginally posted by deevergoteInstalling a turbo and planning to tune later is kinda like having sex and planning to put the condom on afterward.
X2 on that. If there was a simple "tighten screw for better throttle respons and acceleration" trick, it would everywhere on the forum.
Get that idle fixed too. Your car isnt supposed to be idling around 1.5k all the time. Manual/Honda says 700 range if i remember correctly. They are smart so for stuff like that, i usually take their advice.
