Fast Acceleration
    Fast Acceleration
    alright well my friend did a little mod to my car he took off the cruise control wire and he loosened up a bolt that supposebly gives the acceleration a quicker response , now every time i press down on the accelerator the response is alot quicker , so my question is if does anything bad to the accelerator and what this technique is called ???
    http://www.cb7tuner.com/vbb/showthread.php?t=157630
    IT's all in your mind bro
    Originally posted by lordoja
      how is it in my mind im just wondering what this mod those to it cuz now my idles at 1.3-1.5 and my acceleration has a quicker response to it ..
        Its all in your mind. You think you did somthing to make your car faster and now your looking for it and some times your mind tricks you into beliving it happend. If you floor it you open your throttle up 100&#37; loosening some bolt for cruise control wont let anymore air/fuel get in therfore this mod did nothing.
          get a 8lb flywheel...then youll feel real quick acceleration.
          '09 Mini Cooper S (R56)
            he just set your idle higher so it launches quiker i did the same thing
            92 Accord EX - SOLD
            PSN: REDxMAN-_-
            MR===>http://www.cb7tuner.com/vbb/showthread.php?t=146478
              That is such a goofy mod
                [QUOTE=Tippey764;2433809]Its all in your mind. You think you did somthing to make your car faster and now your looking for it and some times your mind tricks you into beliving it happend. If you floor it you open your throttle up 100% loosening some bolt for cruise control wont let anymore air/fuel get in therfore this mod did nothing.[/QUO
                ok all i know its next to the throttle body and the wire that he took off was the cruise control wire thats connected to the accelerator wire plate or whatever its called and now everytime i step on the accelerator i barely have to tap it or else ill haul ass lol
                  lol higher idle = hard on the mounts
                    am i trippin or does nobody know wtf it is ?????????
                      i just said what it was he set your idle higher thats it
                      92 Accord EX - SOLD
                      PSN: REDxMAN-_-
                        hahaha alright and for the cruise control wire thats loose now whats that suppose to do ???
                          sounds like he just tightened the throttle cable. As in he tightened it too much so its constantly applying slight throttle causing it to idle higher. You didnt gain anything.... you just have to press the peddle down "less" to open the throttle the same amount because its already being held open by the over tightenede cable.
                          Thats my theory. accept it or not
                          Installing a turbo and planning to tune later is kinda like having sex and planning to put the condom on afterward.
                            id say nothing but be a saftey hazard..tighten it back up b4 you use your cruise again
                            92 Accord EX - SOLD
                            PSN: REDxMAN-_-
                              X2 on that. If there was a simple "tighten screw for better throttle respons and acceleration" trick, it would everywhere on the forum.
                              Get that idle fixed too. Your car isnt supposed to be idling around 1.5k all the time. Manual/Honda says 700 range if i remember correctly. They are smart so for stuff like that, i usually take their advice.
