im wondering what kind of suspension i need for my cb i will replace the oem and i want to drop the car a lil ... any brands strut and springs or both together im looking to spend around 400 $ on suspension .... i need to change all control arms ball joints and the tire rods any sugestions on this too ? i know that it will be pricey but im looking to get my cb7 in the best shape for the summer
suspension questions
well you SHOULD replace the parts of your suspension that are actually important, instead of lowering it. lol
TASauto.com will be your best bet for most of your parts. tie rods, ball joints, ect.
and if you really want to lower your car, there is a suspension sub-forum that has almost all the info you would need for deciding on a setup.
Originally posted by 92jdm View Poststock springs. lol
gr2s are basically an oem replacement.
i have no personal experience with them, so i can not really ensure you of anything.
there are a couple members who have gr2's paired with lowering springs and haven't had any issues.
how good are this ones ? should i get this kit ? http://cgi.ebay.com/ebaymotors/TOKIC...ht_3657wt_1165Last edited by Ramx; 02-18-2010, 04:34 AM.
That's a good kit. Those shocks are very much like the GR2s, nearly stock replacements... but those springs are also the correct spring rate for them. The drop will be subtle, and the ride will feel very much like stock.
You will need to at least get an alignment after you change everything. A drop that slight shouldn't really require camber correction.
