I Need An Answer! Key Stuck.
    well my neighbor was being stupid with my keys and tried to put it in his cd5 well the key went in and started his car. but it won't come out. how can I get my fkin key out of his ignition? It is my only key to my car. the key is stuck to where it is in the accessory position and it will go to on and start. it will not go into the off positon. It's like the key isn't long enough to trigger the release to turn it back.
    Originally posted by scudweiser
    once again people, need i remind you that there is no road between the kitchen and the bedroom, and therefore women need not drive?
    is it in "park"?
    92ex CB7<-SOLD 93ex CB9shiftingshift73C10
      Shit. That's not cool. I suppose you've tried everything in the books to get it out, including jiggling the shit out of it, etc? My guess is that two of the matching teeth on either side are "locked" into the cylinder housing, as either a security measure or more of a simple PITA.
      Someone else got any ideas?? that's shitty man. I'd never let anyone even breath on my key again let alone borrow it to try in their car. Not after my last Escort key got stuck in a Tracer. It came out eventually but it ended up breaking the key ring end of it...
      life is good.
        Try jiggling the steering wheel or rocking the car back and forth?
        You could also go down to the local honda dealer with your cars title and have a new key made so you can at least use your car if you cant figure this out.
          yes it's in park, I've tried jiggling everything. I didn't take anything apart because I wanted to come ask before I broke something. If I do break it while trying to get my key out more then likely I'll have to pay for it. :[
            explain what you did?
              Did you push it and turn it to the off position?
              1996 Honda Civic LX 2009-2012
              2012 Kia Optima LX 2012-2013
                Take your key off his key ring. Leave your key in his car and let him break shit. Its not your fault he put your key in his car.
                  the key will not go into the off postion. and this is the only key that I have to my car. so I'm fucked.
                    This kina happened when i was starting my buddys car, it was the correct key but the ignition is kina goin. Got it to turn on but the key wouldnt turn the car off or come out, so the car was sitting there idleing and we couldnt shut it off. HE got it out, i think he turned it TOWARDS the start position while it was running somehow, didnt notice any starter grind but then he quickly turned it back in one swift motion and the thing popped out. We were intitially testing to see if his oil cooler was still leaking, fortinately it wasnt, could have been terrible to watche all the oil drain out on the floor and helplessly watch the car kill itself, unable to shut it off... Thank god!
                    _____________________________________________
                    2 year ASE Certification/Auto Technician Degree completed
                      Try to twist it out as hard as you can, might bend the key.
                      Or, take out his ignition cylinder with your key in it. When you get it out, set it on the ground. Go into the garage and grab a BF hammer. Then just hit it till it breaks apart and you can get your key out. Then tell him to suck it and go get a new ignition cylinder because he screwed up your key.
                        take his key and put it in your ignition.
                        峠 で ドリフト を して 下さい。
                        steam linky facebook, y0 俺 は 走り屋 です。 clickable ^
                          Lol... Then they both have stuck keys!
                          Click it.... You know you wanna
                          Bought from:Joshy,H22WAGON93, nho93accord,90accordLXGUY,phantomCB7,Tommi
                            90cb7sleeper and GunRunner had this same issue.
                            You don't even want to know how it ended...
                              dude go to the dealer or locksmith with your vin # and get a copy and let him deal with his car he is fuck not u
