eletrical current runing threw throttle cable
    edit:
    i tightened the negative terminal and that helped out. I followed thr ground wire to thr tranny and the wire was really corroded there and exposed. What can i do now?
    Ok my car started having major eletrical problems recently. headlights get dim, radio cut off, hitting the open/close lock or the window up/down switch would dim the headlights or cut the radio or for a few seconds. also when steping on the brake it happens. also a few times a light smoke came from uder the steerig wheel. i just realized the smoke was the plastic around the throttle cable melting and holding it in place and unable to drive. this must have happened twice to the old one and new one.
    Also i looked and saw that where the cable connects to the pedal. it was sparking. i couldnt figure out why this was happening. this explains the smoke. i took the new cable off and saw the plastic has melted by the pedal ad stop the cable from being able to move freely. i need to solve this problem before i replace it a 3rd time. also sorry for the way i posted but im on my phone.
      your not running a power wire for an amp through the same grommet as your throttle cable are you? Just curious, it's the first possible issue that came to mind. our throttle cable should never do that unless something carrying current next to it shorts out and grounds through it.
        x2 on this/\/\
        and theres the power wires from the radio/cig lighter could be grounded to the shifter witch is the frame.i would say check the back of the lighter cause that wire shorted out on me and grounded itself to the frame from changeing the stock radio.
        my new turbo build
          No power cable for an amp running through it. it must be another power line shorting out near it. i check again tomorrow. what and where should i be looking because i glanced at it and didnt notice anything. it has to be something down there shortingout onto the cable.
            reconnect the ground wire going to the motor
            it got disconected, so the only thing thats grounding its the batt
            since electricity chooses the path of less resistance, with no ground from the batt to the motor, the runner up is the throttle cable
            Just do what PR CB7 said.
              right on good sir, the same thing happend to me after i put a head on my old 92. left 2 or 3 grounds off and the throttle cable was the best one left lol. the plastic sheething it was in melted and burnd the SH!@ outa me. the lights went crazy on me the guages started going to zero the head lights went dim. made some new ground wires of three guages one 2 for the body and one for the frame. bigest for the frame of coarse. but it was all good after that. id check those grounds my friend. good luck
              Hey yo uhhhhhh fry man!!!!
                OK and where are the ground cables. is it the ground wire that conects to the battry disconnected or a diffrent wire? thanks alot for all the help guys.
                  Bump for my last post.
                    Checked the battery ground today. it was actually loose enough that i could pull it off the batery. i tightened it and then started the car with all the lights and radio on. te head lights was bright and none of the eletronics was shorting out. everything seems good. im putting in another throttle cable in tomorrow. i just wanted to make sure i stop the shorting so i wont melt a third throttle cable. thanks everyone for the help
