I have a 91 accord lx, and i just did a h23a swap with a 5speed conversion. I was having an issue with the spark, which turned out to be the igniter. The car cranks, but will not fir over. Before I fixed the spark issue, it would backfire every so often but wouldnt start of course. Now I do not even recieve a backfire. I have fuel in the rail, but not sure if it is making it to the cylinders. Im not sure if a timing light would work, because i dont know if the flywheel will display correctly. When I installed the flywheel, i didnt make sure the timing marks matched TDC. Could someone please give me a direction to go in, or some type of trouble shooting ideas
Problem starting my cb7
