HID problems?
    HID problems?
    I have this HID conversion kit install in my car and sometimes it doesn't turn on at the first try. I have aleast take 4 try to make stay lid. What is the problem?
    My passenger side ballast does the same. A lot of folks have similar issues. The arc's not striked on the first or second try. Mine does it bad when it's cold.
    life is good.
      I check the fuse outside my hood. I have 30 fuse on left headlight and 30 fuse on the right. I check the fuse box it suppose to have 20 on both.
      Originally posted by fatboy1185 View Post
      Cheap kit?
      I did buy the whole HID kit for $10 at this online place.
        Maybe some some sort of faulty connection.
        1992 Honda Accord Coupe LX
          yeah it could be . I have another issue but I'm going to post it other thread.
            $10 for an hid kit? kinda cheap if you ask me, i got some for about $50 and they seem to be running fine under this cold weather condition.
              You should have purchased a relay harness.
                i was having problems with my visionari kit and they told me to buy the error canceller kit, i did and now i have no problems u mite wanna check em out
                  DDM tuning has cheap kits that work well
                  I would say your ballast isnt getting enough "umph" maybe a relay harness would work?
                  Click it.... You know you wanna
                  Bought from:Joshy,H22WAGON93, nho93accord,90accordLXGUY,phantomCB7,Tommi
                    $10 is CHEAP!!! u need to spend more than $70 on a pair of hids
                      Ive been having the same issue with my low beams. Wut works for me is turning the lights on and wait for about 5-10 seconds, turn them all the way off, and back on. Always works for me. Seems like the ballasts arent getting enough power to charge up. Maybe a low voltage issue.
                        From personal experience, you need to buy an HID relay kit. What's happening is that the sockets that connect to your ballasts aren't supplying sufficient wattage to power your ballasts/bulbs.
                        If you buy an HID relay kit, it will connect directly to your battery or 12V and guaranteed you will never have this problem again.
                        Follow me on IG: @jdm_inspired
                        93 'til infinity
                          Exactly what I said.
                            Technically it wasn't exactly what you said....
                            Past 1990 Accord EX Sedan
                            Past 1990 Accord LX Sedan
                            Past 1991 Accord LX Sedan
                            Past 1993 Accord LX Wagon
                            Current 1991 Accord EX Wagon
