ok so i have the f22b dohc and it never ran right what is a ''chipped ecu''? i would like to know especially if it helps...
chipped ecu?
Originally posted by ztaccord View Postok so i have the f22b dohc and it never ran right what is a ''chipped ecu''? i would like to know especially if it helps...
so lets say you got a header, exhaust, intake and cam. the factory computer will only put out what its meant. so you car could go rich and cause the gas to drain quick, the richer you run, the less powerful your car is.
tuners fix this with programs. they tune (adjust settings) buy using a wideband which tells them how rich or lean the motor is running. onces tuned to the specs of the car, now your car has more power and runs bettermiss my turbo cb7
You need to find a dyno/tuning shop in your area. Around here we have a bunch of import specialty places that will do that kind of stuff, but you will have to find a good shop local to you..
Be forewarned to have a good tune get the wallet ready..
worth it to not murder your motor though =)
DONT BUY A GENERIC EBAY "CHIPPED ECU" it will do more damage then goodLast edited by 91kid; 02-11-2010, 06:14 PM.
Most "chipped" ecus havn't been tested so they can do more damage than good in some cases.
If you want to chip your ecu, you need to have it tuned as well.
My 5.7 LS1 Holden Ute
Originally posted by ztaccord View Postyes deevergote the CEL was on. got it cleared and it still came back on. it was more of my transmission shifting wierd sometimes rather than the actual motor running weird. like until i got to about 30mph it would be boggy...if that makes since?!
"clearing" the CEL is not what you need to worry about. The CEL is telling you that there's a problem. Read the "sticky" threads in this section. You will see how to read the error codes from the CEL. From there, you must fix all the things that the CEL is telling you are wrong.
Also, if your D4 (for 92-93) or S (90-91) is on in your gauge cluster, that's a TCU (transmission computer) error code. That could account for your strange shifting. Read that the same way you'd read the CEL code, and fix that as well.
Originally posted by ztaccord View Postand 91 kid the closest thing i got for tuning is houston ha which is a good 2hrs away:/ but ill do it if its worth it.
