i have a friend selling a his wilwood forged dynolite big brake kit. thay came of a 1992 honda civic. my question is can this me made to work on are cars? also will be doing a 5lug swap. i have bb6 front knuckles.
wilwood big brake question?
Correct deev, there's very few stiff stuff that is shared between Accords and Civics from any years. Now if I can point you in the right direction, but it's serious cash tho.....I hope this is within the rules deev.
Willwood Big Brake Kit
Brembo Big Brake Kit'94 JDM H22A: 178whp 146wtq
Originally posted by deevergoteIf you say double dutch rudder, i'm banning you...
Originally posted by Joey GT-R View PostCorrect deev, there's very few stiff stuff that is shared between Accords and Civics from any years. Now if I can point you in the right direction, but it's serious cash tho.....I hope this is within the rules deev.
It should work but it depends on the model of civic that this setup is on. If its a 92-95 civic coupe ex then it should work. Only thing that wouldn't work is the rotors. If you can make a SpecR setup on a civic coupe ex by only getting 11" rotors redrilled to 100x4 for a civic and simply bolt on a set of typer calipers which are the same as a prelude vtec caliper then why wouldn't that caliper bolt up to a prelude knuckle/bracket. Just depends on which model civic your friend has. Ask the guys at fastbrakes.com to help you out, it wouldn't hurt to ask, or do a search on honda-tech.com about this specr brake setup that I am talking about. It will explain things a bit better, but these calipers should work as long as these calipers are on a 92-95 civic coupe ex. For my civic to use lude vtec calipers(same part number as a the typer calipers) on it I merly have to buy these redrilled rotors for it: http://www.fastbrakes.com/product_p/...h%20rotors.htm or these http://www.fastbrakes.com/product_p/...e%20rotors.htm. But if you don't want the hassle pick up a kit that's ment for your model car.Carlos
My Members Ride Page
I bought a Wilwood kit for the 99-02 Civic w/Rear Disc that will fit the stock rotors on the CD chassis. So I'm sure it will fit a CB chassis. You may need to fabricate or buy an Accord mounting bracket. It's is only a piece of 5/8 plate. Easy enough to find a couple quality pieces of 5/8 drop steel and drill it out.
If you need mounting brackets hit me up! Lots of fab shops around my area that will sell it for pennies. Check out your local industrial park for fab shops, the ones around here sell or recycle all of there drop steel.Last edited by GhostAccord; 02-10-2010, 03:37 PM.
