i just picked up my first cb7 today.its a 91 lx coupe with a f22a1.the guy i bought it from said he was going down the road and it shut off and wouldnt start back.when i got it home i turned it over and it cranked but it sounds like a rocker arm was ticking so i shut it off.I disconnected the battery so i can charge it.i put the battery back in with a full charge and i got my brother to look at it and wouldnt crank it turned over though. it was getting fuel but no fire.it has a new main relay on it,that was the first thing i checked.and i checked all the fuses and they were all good.what does it sound to you guys that is wrong with it?.whatever help i can get with this problem would be greatly appreciated
91 lx coupe wont start
Right, but you can still test the resistance of the coil. If it's low, then that might be one added reason. If it sparks, and your ignitor circuitry appears to be fine it could still be that the ignitor has a fault. In that case, from the negative side, Pull the two connectors to the coil and the wire that goes to pin 2 on the ICM. Then hook up a 12V test light between the 12V negative coil wire and pin #2. Have someone else try to start the car, and see if the ICM still flashes the test light.
life is good.
