vacume leak
    vacume leak
    hey i have a 90 cb7 with the stock f22, all i have is an intake on it but when my car is warming up it starts to rev up and down as would happen witha vacume leak i cannot find the leak if you have any suggestions on where it could be leaking?, it would be well appreciated.
    well it could be that you have to set your idle properly. try doing this DIY, it should help.
    http://www.cb7tuner.com/vbb/showthread.php?t=146239
    where in colorado are you from?
    Rip It Up
    Sold to: nightime25, MyDianaz06, Accord214 and 408cb7
    Bought from:Rob_is_Legend, MonoCB7, Fatboy1185, Flatline and busak87
    i vouch for my Brothas
      awesome ill try that out tomorrow
      thanks.
      im down in aurora.
        sweet man, another member in colorado! and if that doesn't solve the problem then try checking your vacuum hoses and see if they are all connected. if that doesn't help then try to clean you idle air control valve.
        Rip It Up
          I have a vacuum leak as well... And I have set my idle properly and cleaned it all out...
          It still revs from 1000 to 1200 when it's idling...
          Needa fix that damn leak
            its your iack val to fix it you need phillups and a flat head on top of the intake next to your idaler val on top of that theres 2 phillups scws undo those and theres a spring take that out and in there there is a white plaic tab and take a flat head scwdriver and *** it down and that should fix your problem...
