hey guy and ladys i have a question. my timeing belt just gave out on my cb and i have 350,000 miles on motor. should i swap motor or just fix the timeing belt for now. how much does it typically cost to replace the belt compared to motor swap?
to change or swap
I would check www.Hmotorsonline.com to get a motor and then see how much the shop wants for labor
Real talk
i would just find a friend of a friend who fixz cars and find a clean used A6 head from a junkyard with less miles and replaced it with new gasket and timing kit and keep the f22 runnin untill you find a cheap Dohc swap around youre town or have enough save up for it.." its just a single cam "
Originally posted by 93layback View Posti would just find a friend of a friend who fixz cars and find a clean used A6 head from a junkyard with less miles and replaced it with new gasket and timing kit and keep the f22 runnin untill you find a cheap Dohc swap around youre town or have enough save up for it..
i would buy a replacement engine or find an h22/23
a snapped timing belt could have caused some internal damage
i.e. bent valves leading to ruined head
plus youve got a solid 350k miles on it anyways if you replace the engine you can drive your cb7 for another 350k =]
AND since you live in TN i could prolly help-Tyler
Originally posted by Tippey764 View PostYour motor will most likely need work if the timing belt broke while it was running. Just swap out a new one and sell/build the old one.
What he said. You are probably going to have bent valves in your existing engine due to the effects of the timing belt breaking, so swapping in another motor is quicker. then you can fix up the old one in a relaxed way if you want to.
