need help! cb wont start!
    ok so the other morning i was going to school.
    so i started the engine and let it warm up... maybe 2 minutes later the engine started reving by itself reaching 3krpms and then back to 1 then back to 3 untill it just died. i started it again and it did the same thing and died. i tried once more then it wouldnt even start, tho the engine would crank and shake. then after a couple more tries it didnt even crank.
    the mpg has also dropped significantly from 29 easily to just over 20.
    i noticed this int he past week or so.
    i recently put an aem cold air intake but thats the only difference i can think of at the moment.
    anyone else have this problem? or may know a solution?
    That seems pretty unsusual.
    OK , first things first.
    - Are you getting spark?
    - Are you getting fuel?
    - Are you not getting both spark and fuel?
    - Any loose grounds?
    - Starter condition?
    - Battery condition?
    - Alternator condition?
    - Alternator belt condition?
    I would also check for vaccum leaks. An unexpected rev is probably a cause of a vaccum leak.
    EXTERMINATE ALL MUFFINS!
    I WANT YOU! TO JOIN THE CAKE MILITARY SERVICE.
    DO YOUR PART! FOR YOUR SWEET-TOOTH!
      hi hi welcome read this post #6 http://www.cb7tuner.com/vbb/showthread.php?t=65668
      and i would put in new plugs also
        What's your engine temp while this is going on? Is the gauge read within its normal range?
        Previous: '92 Accord EX Coupe
        Sold To: zack_odom
