i have a 92 ex and my trunk will not close. when i push the trunk to close it bounce back up i changed the trunk latch and it still doing the same thing
Have u tried to fool around with the trunk latch inside the car? If you've replaced the latch then I would make sure the lock is not sticking. Maybe stick the key in there and turn it around a bit. I would maybe remove the lock and spray a little lube in there all around the moving parts and what not. I would also try disconnecting the trunk latch and see what happens with that. IDK, I'm thinking it has to do with the lock itself.
is there any way i could change the cable to me the cable is kind of messed up but i neva had this problem wit it beforeLast edited by 92accordkidd; 02-02-2010, 12:00 PM.
Originally posted by HardInThePaint View PostJust remove the cable off of the latch. The cable is only for the lever in the car so it isn't necessary. See if that does anything.
Ken
Originally posted by AllWhiteCoupe View Postthis happened on my last Cb. I took a hammer and banged on the 'U' shaped latch on the car itself, on the bottom, not the trunk lid. Mine came loose and slid down about 1/4" and wouldnt let the trunk latch catch. Try tapping it up a and see if that works.
Originally posted by troy View PostYou said it's a new lock? When you installed it, maybe it's not perfectly lined up?
I had a similar issue, but I was able to fix it by turning the key back and forth (it somehow got to the locked position while the trunk was open).
