auto tranny question?
    ok so I have a cb7 SE with auto transmission. when i drive in the freeway at 65 mph my rpm needle is at 34,000 is that ok? which is the proper rpm?
    Turbo F22 Under Construction
    You mean 3400?
    Yes, that's normal. It should be in 4th gear. If you want to check to be sure, count the shifts. Pull over on the side of the highway, and accelerate from a complete stop, up to 65. It should shift 3 times.
      yea i mean 3400. thanks for the info
        well at 70mph in 4th gear and in torque convertor lock-up the needle should read about 3,100rpm so the toque convertor may not be locking up
        '90 Accord EX
          I know that my 92 ex at at 70 im at 2900rpms. I have some issues with the cold and my torque converter locking up sometimes.
