Well i finally got a set of wheels, but the stock lug nuts won't work obisoully. I wanna know what kind I should, since I don't want to buy the auto zone ones. Lol
Lug nut question
hi you could get this one http://www.tasauto.com/Product/Detai...148&d=1586&p=1 if you do not have center caps or this one if you do http://www.tasauto.com/Product/Search.aspx part # 181144 thay are $1.50 ea
Originally posted by 92smokeaccord View Postdo not get the ones were the key goes in the lug nut.watter will get in there and rust out and seize up then you will never get them off un less they break.
what kind of wheels do you have? depending on the diameter or the hole, you either need spline lugs or just any quality set will do. you could go cheap and go with muteki ($50-60) or go expensive and go with Works or Rays ($120-150). if you got a lot of money then go with Project Kics ($190+).
either way you'll want to invest in a quality set of locks as most of those lug sets dont have that great of locks. but then again if a thief wants your wheels that bad, they will get them.
