h22 swap questions
    h22 swap questions
    new to the site, uhm kinda confused on the swap. i want a JDM h22 with lsd and from what ive seen i just need the h22 axels, i will have to extend a few wires, re-do the auto timing tensioner to manual tensioner and thats it besides the actual swap. is there anything else i am going to need or need to do? help would be appreciated.
    are u auto or manual..?
    WHEN LIFE PASSES YOU BY...DOWN SHIFT...
      H22 Swap Parts list
      Swap FAQ
      Originally posted by chessboxer
      We know these are good cars, but for some reason, all the world wants are freaking civics and tegs. Bleck.
      Bought From: Slammed4thGen TypeG x2DeevergoteBillKisme
        Manual.
          Use the Accord axles. The Prelude axles are too long.
          You have to add 4 wires, which is shown in detail in the swap guides linked above.
          You have to tap a new hole in the transmission casing, and use the Accord mount.
          Use your Accord fuel rail, because the JDM fuel rail goes the other direction.
          The tensioner swap is not mandatory. The auto tensioner CAN fail, but it's not a terribly common thing. The manual tensioner is just more reliable (of course, if you screw up installing it, that won't be true... I didn't convert mine, and it's been fine since 1994... still has the original timing belt, even!)
