ok so the cb7 i have is my first 5spd (yay!) lol but in all seriousness, im a noob at driving a standard. so i have a couple questions regarding the clutch. is it normal for the clutch to grab so high? and when i try to floor the car, it seems like the clutch "slips" if u wana call it that. i try to accelerate hard but it just revs high and im going the same speed, if anything im slowly gaining speed. clutch? or flywheel problem? other than that, i can drive fine without stalling now.
clutch problem
clutch problem
Members' Ride Thread :http://www.cb7tuner.com/vbb/showthre...82#post2939682
My CB7 Tribute Vid..https://www.youtube.com/watch?v=XqWFstSzLH8
Track ready EK..https://www.youtube.com/watch?v=IoYKsoL0i7MTags: None
"so high" isn't exactly something that anyone but you can measure, so we don't know if that's the proper engagement point or not. You can adjust the engagement point.
If you are completely off the clutch pedal and the engine revs, but doesn't move the car (and it is in gear)... then yes, your clutch is slipping. Badly. Allowing it to slip will ruin it further, until it doesn't work at all. It would be smart to replace it before you find yourself unable to move in the middle of an intersection.
thanx deev. but it seems like the clutch is very worn for a car with only 128k. maybe the previous owner was a bad driver and let the clutch slip constantly? idk i only had the car for a month or so.
x2. It depends. If a granny has your accord, and never revs past 3k rpm and sells it to you because she can't drive standard anymore, the clutch would probably be in better shape than if you bought the car from some 16 year old who does burnouts and attempts to double clutch everywhere, and who doesn't know how to drive...
I bought my old civic from an older couple, it had 180k on the stock clutch, and flywheel. I don't beat on my cars ever, so I went another 20k before deciding to replace it. It probably could've gone a little longer, not long. It was starting to get worn by that time.
There's so many variables, it's hard to know. If the clutch is letting out "high" it is still vague as to why this is usually, because without it functioning properly it's hard to know where the point it normally lets out, is. I assume you haven't attempted to adjust it yet?
If your revving and not going any faster whilst in gear, then yes, it's slipping a bit.
life is good.
thanx guys. im gonna let a buddy of mine drive my car to test the clutch. he's more knowldedgable about standard cars and will kno if the clutch is bad. thinking of excedy and fidanza..im getting excited lol
