tranny leak. fix please?
    okay well i just replaced the tranny and when i first started it up the tranny kept leaking from this ps line (i think thats what it is). i replaced the bolt that held it in there with the washer and its leaking less but still leaking. its a perfect tranny so id hate to mess it up. any way to fix the leak?
    heres a pic
    the bolt that i replaced was the one to the right of my finger. as u can see the tranny fluid is sitting right under it.
    im going to try putting two washers , one under and one on top of the line and if that doesnt work im going to replace the hardline.
    urgh more and more problems keep coming !
    alone in this game . ::My Ride My Way::
    is the washer supposed to go in between the bolt and the line or the line and the tranny ??!? this could be why its leaking ..
      I think both. a washer in between the line and transmission and another between the line and your bolt.
      www.stl-imports.com
      Referral: crx08
      support the import community
        well my dumbass lost the washer it had on it about an hour ago trying to adjust the bolt right. im going to buy two washers and try that, if not im going to replace that hard line and see if it works.
          is there any way i can jb weld this or something ? im losing a lot of tranny fluid. leaving a trail behind me wen i drive.
          please i neeed suggestions! !!!!!!!
            Looks like a quick trip to the Junkyards! I wouldnt jb weld anything.
              awww shiett...g/l though. you prolly missed a step somewhere, but dont worry, leaks are usualy easy fix, just need to find the right thing.
              '09 Mini Cooper S (R56)
                i put a pipe on the wrench and tightened it some more. i drove around for a bit and found no more fluid. hopefully that did the trick. ima refill the trans and try again.
