go with a k&n filter, any pipe will work. spend the money on the filter or you'll be suffocating your engine
Cold Air intake?
This topic is closed.
2013 Ice Cream Cruise!
VIDEO: 2012 Ice Cream Cruise
VIDEO: 2012 Ice Cream Cruise part 2
The single largest cruise in the Midwest!
August 3 ~ Omaha, NE
By 1320 Video
Member's Ride Thread
Originally posted by Status Quo View PostRight now I am just looking for sound. Would I be better of going for a short air?
i drive in rain a lot so i like the short ram..the long one [cold air ] has more power but you have to watch out for water
Originally posted by Teddy View Postyou could get a filter [cone] and adapter at autozone for $25 then you can drive in the rain like this
Bought From:
CB7 Sleeper
illestatus
HondaFan81
My Ride:
http://www.cb7tuner.com/vbb/showthre...92#post2587592
I am thinking bout SRI with K&N filter.
Thanks Guys!
Bought From:
CB7 Sleeper
illestatus
HondaFan81
My Ride:
Short ram is better IMO, when at high RPM's the motor need more velocity air, in which case when running a CAI it has to suck up all the air all the way down from the filter and the motors suffers a bit (at high rpms) even though you still get good ponies for having the filter were it not really hot, even though you still get hot air running in the motor because of the piping, unless you get some heat wrap for the intake pipe or somthing.
When the motor is at high RPM's the motor need more velocity air, in which case when running a SRI it sucks up all the air from that the filter (which is really close to the TB) and get more air at higher RPM's.....I really can't explain it good but something like that tho.
But having a CAI does change the tone of the car when you hit torque (atleast thats what I heard when I ran my CAI). As for short ram, you get the chance to avoid the rain or water.
But when having cold air intake your risking of getting water in your filter (when it rains or there a puddle or somthing around)
But its up to you brotha, its your car your choice, I just gave you my thoughts and opinions....
Though you can also get an h23 intake manifold (if you have an f22a1 or a4) and remove the butterflies, and install it in your f22a, if you got and f22a6 you can just remove the f22a6 plenum and install an h23 plenum and remove the butterflies as well. You get more power of that to!Last edited by pedroalcala; 01-25-2010, 10:51 PM.
Originally posted by pedroalcala View Postshort Ram Is Better Imo, When At High Rpm's The Motor Need More Velocity Air, In Which Case When Running A Cai It Has To Suck Up All The Air All The Way Down From The Filter And The Motors Suffers A Bit (at High Rpms) Even Though You Still Get Good Ponies For Having The Filter Were It Not Really Hot, Even Though You Still Get Hot Air Running In The Motor Because Of The Piping, Unless You Get Some Heat Wrap For The Intake Pipe Or Somthing.
When The Motor Is At High Rpm's The Motor Need More Velocity Air, In Which Case When Running A Sri It Sucks Up All The Air From That The Filter (which Is Really Close To The Tb) And Get More Air At Higher Rpm's.....i Really Can't Explain It Good But Something Like That Tho.
But Having A Cai Does Change The Tone Of The Car When You Hit Torque (atleast Thats What I Heard When I Ran My Cai). As For Short Ram, You Get The Chance To Avoid The Rain Or Water.
But When Having Cold Air Intake Your Risking Of Getting Water In Your Filter (when It Rains Or There A Puddle Or Somthing Around)
But Its Up To You Brotha, Its Your Car Your Choice, I Just Gave You My Thoughts And Opinions....
Though You Can Also Get An H23 Intake Manifold (if You Have An F22a1 Or A4) And Remove The Butterflies, And Install It In Your F22a, If You Got And F22a6 You Can Just Remove The F22a6 Plenum And Install An H23 Plenum And Remove The Butterflies As Well. You Get More Power Of That To!
ok, so I looked at the TASPRO Hybrid intake system.. seems interesting.. BUT, there is where im confused.. The stock air box has that little inlet/outlet piece that goes beneath the fender, and I know all of you already know this. Well where i get confused is, they have the CAI and short ram for better air flow. well with the TASPRO you still have that little tiny inlet/outlet piece sucking up the air into the new filter and hose piece. So, how is the TASPRO really beneficial? It seems like all you are doing is replacing the filter with a better one and the intake hose with a metal shiny one?
I dont mean to seem ignorant, but am i wrong here? please let me know if i am
and the ebay intake set ups arent carb certified which is why i havent bought one yet.. but i think i still may take the risk.
Originally posted by barry92lx View Postok, so I looked at the TASPRO Hybrid intake system.. seems interesting.. BUT, there is where im confused.. The stock air box has that little inlet/outlet piece that goes beneath the fender, and I know all of you already know this. Well where i get confused is, they have the CAI and short ram for better air flow. well with the TASPRO you still have that little tiny inlet/outlet piece sucking up the air into the new filter and hose piece. So, how is the TASPRO really beneficial? It seems like all you are doing is replacing the filter with a better one and the intake hose with a metal shiny one?
Originally posted by b16hatchsi View Postyes CAI has more power gains but i would stick with a short ram as well..heard about too many of my friends blowing their motors due to rain being sucked up by the intake being so low to the ground. play it safe and go short ram mang
Good luck with whatever you choose Mark.
Wow, now that I really read through all of these posts, I want to rip my hair out. There is so much misinformation in this thread that it is rediculous. It seems you all have just heard this about a CAI and heard that about a SRI and assumed it was all true. Most of you seem to have little to no idea how an engine works, and how an intake system is beneficial. If you had any idea how an engine worked, you'd be able to think for yourselves and realize that a lot of the things you've heard are wrong. You are posting based on what you have heard with no experience or knowledge to back up your facts, which are not true facts at all.
I don't even want to get into this right now, because I could go on forever correcting a lot of you.
Originally posted by CB7 Sleeper View PostWow, now that I really read through all of these posts, I want to rip my hair out. There is so much misinformation in this thread that it is rediculous. It seems you all have just heard this about a CAI and heard that about a SRI and assumed it was all true. Most of you seem to have little to no idea how an engine works, and how an intake system is beneficial. If you had any idea how an engine worked, you'd be able to think for yourselves and realize that a lot of the things you've heard are wrong. You are posting based on what you have heard with no experience or knowledge to back up your facts, which are not true facts at all.
Honestly, the best way to go in my opinion, is a good drop-in filter. AEM makes good ones, the K&N ones are alright. The TAS hybrid setup is neat, as I explained and some others stated earlier. And you do pay for what you get. If you do decide to go with a 3" intake with open air filter setup, it's not so much the construction that's reflected when spending extra on a name-brand intake, it's more a matter of better fitment. But do what you feel, just don't get the wrong idea that an aftermarket intake brings some 'sw33t powur incR34s3s y0'.
life is good.
Originally posted by DJ metadelic View PostSadly, Kevin is right. You'd be lucky to realistically see a 5whp gain from a SRI, especially after heatsoak. You'd be even luckier to realisically see 8whp increase from a cold air. They're pretty much meant to look "rather" aesthetically pleasing, and make a cool little noise
