need help wiring vtec
    ok i've been reading and reading on how to wire it up but when i look at a4.. i see it but d6 and d2 im lost right there some pics on where those last two are at would help thanks
    WHEN LIFE PASSES YOU BY...DOWN SHIFT...
    edit:this is a cut&paste from superhonda...apparently there are some wire colors that differ among car models but the ecu pins are the same
    KEY:
    (voltage values measured in DC Volts unless otherwise specified)
    V = Volts
    Wht = White
    Blk = Black
    Grn = Green
    Yel = Yellow
    Brn = Brown
    Blu = Blue
    Org = Orange
    KOEO = Key On Engine Off
    KOER = Key On Engine Running
    A, B, D= Slot. Numbers are read up and down from left to right, not straight across (see diagram at end).
    A1-INJ1 INJECTOR#1 Brown, Battery Voltage with KOEO
    A2-INJ4 INJECTOR#4 Yellow, Battery Voltage with KOEO
    A3-INJ2 INJECTOR#2 Red, Battery Voltage with KOEO
    A4-VTS VTEC solenoid GRN/YEL, n/a
    A5-INJ3 INJECTOR#3 Blue, Battery Voltage with KOEO
    A6-PO2SHTC O2 sensor heating element Org/Wht, Battery Voltage with KOEO
    A7-FLR1 fuel pump Grn/BLK, Battery Voltage with KOEO
    A8-empty A7 and A8 have the same circurt, so they can be the same
    A9-IACV IAC valve Blk/Blu, About 10v KOEO on Warm engine
    A10-empty
    A11-EGR Control Solenoid Valve (if the ECU has it) Red, n/a
    A12-FANC engine coolant temp switch Blu/red, n/a
    A13-MIL MIL (check engine light) Blu/wht, n/a
    A14-empty
    A15-ACC (a/c compressor clutch) Red/Blu, n/a
    A16-ALT C alternator Wht/Grn, n/a
    A17-IAB IAB Solenoid Pink, n/a
    A18-Org/Red, Transmission Control Module (A/T), n/a
    A19-White, Intake control solenoid, Battery Voltage with KOEO
    A20-PCS EVAP purge control solenoid Red/Grn, n/a
    A21-ICM Yel/Grn, Ignition Control Module output signal, About 10V KOEO
    A22-Igniter, same as A21
    A23-PG1 ground Black, Power ground, less than 1V
    A24-PG2 ground same as A23
    A25-IGP2 to main relay and to ground Yel/blk, Battery positive from Main relay, Battery Voltage with KOEO
    A26-LG1 gound Blk/red, less than 1V
    B1-IGP2 to pin A25 Yel/Blk, Battery positive from Main relay, Battery Voltage with KOEO
    B2-LG2 ground to shields for CYP & TDC Brown/Blk, <1V
    B3-Orange, upshift/downshift comparative input, n/a
    B4-Pink, upshift/downshift comparative input, n/a
    B5-ACS a/c switch Blu/Blk, a/c input, ~5V with KOEO & A/C off; <1V KOER with A/C & blower on
    B6-empty
    B7-Light green, Park/Neutral switch (A/T), <1V in Park or Neutral with KOEO; 5V in Park or neutral with KOER; Battery voltage in all other positions
    B8-PSPSW PSP switch Red/Green, Power steering oil pressure switch, 0V KOEO; Battery Voltage KOER While slowly turning steering wheel
    B9-STARTER SIGNAL starter signal Blue/red, Battery Voltage in the START position (clutch depressed on M/T models)
    B10-VSS vehicle speed sensor Orange, Pulses 0-12V while turning the left front wheel
    B11-CYP P CYP(#1 piston position) -P Orange, CYP sensor input, n/a
    B12-CYP M CYP -M White, CYP sensor signal, n/a
    B13-TDC P TDC(top dead ceter) -P Org/Blue, TDC sensor input, n/a
    B14-TDC M TDC -M Wht/Blue, TDC sensor signal, n/a
    B15-CKP P CKP(crank position) -P Blu/Green, CKP Sensor input, n/a
    B16-CKP M CKP -M Blu/yel, CKP Sensor signal, n/a
    D1-VBU Back Up Power Wht/Yel, Battery positive From battery through Fuse Box, Battery Voltage at ALL times
    D2-BKSW brake switch Grn/wht, Battery voltage at all times
    D3-KS Knock Sensor Red/Blue, n/a
    D4-SCS service check connector Brown/Wht, ~5V (M/T); ~11V (A/T)
    D5-empty
    D6-VTM VTEC pressure switch Light Blue, n/a
    D7-TXD/RXD (data link connector) Light Green/Red, n/a
    D8-empty
    D9-ALT F alternator Wht/Red, Alternator Charging Signal, ~4.5V KOEO; Decreases under Electrical load (Headlights & rear defogger on) At warm idle
    D10-ELD electric load detector input Grn/Blk, n/a
    D11-TPS (throttle position sensor) Signal Red/Blk, ~0.5V KOEO with throttle fully closed; ~4.5V KOEO with throttle fully open
    D12-Wht/Blk, EGR Valve Lift sensor, ~1.2V KOEO
    D13-ECT (engine coolant temp) sensor input Yel/Blu, ~5V KOEO (varies with temperature)
    D14-PHO2S O2 sensor White, heated 02 sensor Signal, 0.4-0.5V when ignition is turned on; drops to less than 0.1V within 2 minutes
    D15-IAT Intake Air Temperature sensor signal Red/Yel, .05-4.5V KOEO(Varies with temperature)
    D16-VREF (no info)
    D17-MAP Map Signal Wht/Blu, ~3V KOEO (Varies with Temperature)
    D18-Light Green/Blk, Transmission Control Module (A/T Only), n/a
    D19-Red/Wht, Reference Voltage, ~5V KOEO
    D20-Yel/Wht, Reference Voltage, ~5V KOEO
    D21-Blue/Wht, Sensor ground, <1V
    D22-Green/Wht, Sensor ground, <1V
      shit thanks bro thats all i needed
        ok i just got done wiring it and im using the p13 and i went to go drive it and it bogs on me on 1 2 and 3 also the knock sensor has two wires one with red/blu and the other one im guessing it a ground right its just wire
          I need to wire my vtec for my h22 what pins go to what with p13? 94 si Prelude
          MIKE KOLODIEJ #11
            Knock sensor should just be one wire, well thats how it is on my Prelude.
            www.PreludePower.com
            BB SQUAD MEMBER #28 V.2
              This post is nearly a year old. That member doesn't even post anymore, it seems. The guy above you revived this thread.
              gtaboy24, are you saying that you have an H22 in a 94 Prelude Si?
              The wire colors may not be the same between your car and the cars that this forum focuses on.
              The P13 pin layout is in the diagram and list posted above. That's the information you need, right there.
