As the title states I'm getting CEL code 6 "coolant temp sensor", did some research into it and thought it was the sensor under the "dizzy"
Well I changed that out and I'm still getting code 6 and a flashing s light.
I'm guessing its the sensor at the top radiator hose, I do not know where the 3rd sensor is located.
As for the TCU code 10 which sensor is that?
BTW, a thanks for suggesting the ground problem in my previous lighting issue thread, I found those 2 semi clear plugs tucked behind and not properly grounded to the chassis. Once I grounded those all my headlight issues went away.
