Remove Head with Intake Manifold
    Can I remove head with intake manifold together?
    I don't know how to get to the bolts on the underside of the intake manifold to head
    yes you can take off the head and leave the mani on
    to get to the ones on the underside just jack the car up and put it on jack stands and go underneath
    ''COUPE''
    ''WAGON''
      i'm going to try leaving it on. if it is too heavy then i'll go underneath
        You can also just get a long extension and reach your hand under it. I have done it many times its pretty easy after you get the first few.
          it`s much better to take off the intake first..there is a bracket from the back side of the motor ,you have to remove a bolt out of it.. and part of the cooling where the thermostat is if you remove it you can get at the bolt that go from the intake to the head ..i just think it would be better to take it off first
            In the end, it'll be much easier to remove the IM first, separating it from head.
            life is good.
              at the shop every time we pull a head we leave the I'm attached it's makes life easy cuz most cars come with a bracket that attaches the I'm to the block just remove the bolt from 1 side or the other and the whole unit comes out easy in my experience it's easier to leave it on
                Are you pulling the head JUST to remove the intake manifold? If so, that's the dumbest thing I've ever heard.
                If you pull the head, you had better be prepared to replace the timing belt, water pump, and head gasket.
                  dee is right if ur just tryin to pull the IM then it isn't to smart to pull the head ur best bet in that case if you don't want to get underneath the car is use a long extension and reach under the IM to remove the nuts
                    The last time I did it I went in from the top with a ratchet and extension. Most of the time when people ask this question the consensus seems to be to do it from the bottom though. I've only done it once and from the top it wasn't too bad but alot of it you're doing somewhat blind. You could probably see better from the bottom. What exactly are you doing to your motor?
                      Please don't call me dee. I am not a woman.
                          head gasket no tuning here. Try to get my car to 1 million miles club
                            x2
                            And I think he means removing the head in general, with the IM still attached.
                            life is good.
                              Originally posted by DJ metadelic View Post
                              x2
                              What gave it away? J/p. Yeah that's what he's talking about.
