i just did a 5 speed swap on my cb7 and for some reason the motor doesnt sit right. i changed the rear mount and the front but it still sits wrong. can anyone help me
need help auto to 5 speed swap
Originally posted by Hondapawa View PostThats what i'd have told him if he didnt change the tranny mount.
He probably have changed it otherwise it wouldn't even bolt...
Or you could just purchase the ESP Auto to 5spd conversion mount, that'll avoid all the welding and cutting. I think its 110 shipped or something. Definitely not worth it to do all that work when someone's already done it for you.
Since you didn't bother following plee3's suggestion, I did it for you. Here's the post in his thread that he wanted you to see. Look closely.
Originally posted by plee3 View PostMore random pics.
Auto to manual swap pics.
This thing is history! LOL!
Auto bracket out.
This pic is very important to those of you who are doing the A/T M/T bracket swap. The A/T bracket sits 13 3/4in from the core support. The M/T bracket sits 12 1/4in away from the core support. So the M/T bracket is mounted closer to the core support. Thats why the manual trans will not line up until the modifacation is performed.
A/T bracket location 13 3/4
M/T bracket location 12 1/4
"To those of you who are doing the A/T M/T bracket swap. The A/T bracket sits 13 3/4in from the core support. The M/T bracket sits 12 1/4in away from the core support. So the M/T bracket is mounted closer to the core support. Thats why the manual trans will not line up until the modifacation is performed." You also run a risk of snapping your axles. since your engine sits 1 1/2in back your axles are stretched 1 1/2in out of place. (13 3/4 - 12/ 1/4 = 1 1/21n)
Deev pulled it up for you too! We have given you all the correct information. The only thing we havent done was perform the work for you.
