So my accord is nearly stock, just got my exhaust to replace the pos stock rust pipe and muffler. I routinely do my oil changes (about every 4-5 months), did the spark plugs about a month ago, replaced my fuel filter about 8 months ago, pump 91 octane, replaced spark plug wires, cleaned air filter, replaced cap/rotor on the dizzy, replaced pcv valve, and had my injectors cleaned by the local carb shop(my car is not carb'd obviously tho) about 6months ago and do not have a lead foot (shifts before 3K). I get 19 mpg and recheck every time I fill my tank up, which is about every 2 weeks and it seems to stay right around there. I only get about 275 to 300 miles if i'm lucky. Any suggestions or thoughts as to why my mpg's are so low? Thanks in advanced
19 mpg, why so low!?
Originally posted by 91cblx View PostSo my accord is nearly stock, just got my exhaust to replace the pos stock rust pipe and muffler. I routinely do my oil changes (about every 4-5 months), did the spark plugs about a month ago, replaced my fuel filter about 8 months ago, pump 91 octane, replaced spark plug wires, cleaned air filter, replaced cap/rotor on the dizzy, replaced pcv valve, and had my injectors cleaned by the local carb shop(my car is not carb'd obviously tho) about 6months ago and do not have a lead foot (shifts before 3K). I get 19 mpg and recheck every time I fill my tank up, which is about every 2 weeks and it seems to stay right around there. I only get about 275 to 300 miles if i'm lucky. Any suggestions or thoughts as to why my mpg's are so low? Thanks in advanced-Will
you had the injectors on the flowbench correct? Do you consider warm-ups as a factor for your low mpg rating? It is Winter. But, I just barely noticed you're in CA. Your gasoline might have 10% ethanol. If the weather is cold and you have the lousy mileage gasoline, you may only get 22 to 23 MPG, in your case, less. If you have highway mileage of 34, you are right on the mark. I guess you will have to wait for a long trip to find out anything. Which city traffic you are talking about can make a difference. Also, is this 19 mpg highway? city? poor fuel economy can also be due to a rich mixture. How much oil does the car consume in those 4-5 months?
life is good.
Originally posted by 91cblx View Postwould changing the o2 sensor help with mpg's or is there a way to test the o2 sensor?
Yes my name is Dang, Don't use in vain
1992 Honda Accord EX (Coupe/Bordeaux/Auto)
1992 Honda Accord EX (Coupe/Bordeaux/H22A MT)
2008 Honda Accord EXL (Coupe/SanMarino/6spd)
When o2 sensors go bad they tend to send the ECU bad readings and goes into "loop mode" (something like that) and makes your engine run rich.
Replace that o2 sensor and everything should go back to normal (Gas milage wise)
Originally posted by 91cblx View PostAlright I will pull it off in the morning to check out, that is if there is no storm or tornado watches again lol. Hopefully that is the problem.
Our cars get 22 -29(EX less) Mpg so 19 is right if you are one to hit the gass hard at times. I get 200 miles with a full tank in city driving and close to 400 highway
Links to my rides :
1992 Accord EX*
1990 Accord EX
1991 Accord SE (4th)
1991 Accord SE (3rd)
1991 Accord SE (2ND)
1991 Accord SE
Originally posted by Hondateck2010 View PostOur cars get 22 -29(EX less) Mpg so 19 is right if you are one to hit the gass hard at times. I get 200 miles with a full tank in city driving and close to 400 highway
