power window don't have current to go up
    my passenger side window have current to go down but don't have current to go up.
    i switch the wire around and then it has current to up and none to go down.
    how can i electrically speaking wire it so my window can have current to go both up and down?
    Sounds like a polarity issue. Try replacing the switch. Could be a relay, but that's less likely. Test for upstream signal, thus checking polarity in the circuit. By "upstream", I mean the part of the circuit that is generating and transmitting the input signal to the test point. If the desired signal is not present i.e. the window not going up, when going down, and vice-versa, then you can likely eliminate the circuit "downstream" from the test point and instead focus on the "upstream" part of the circuit. Could also be a wiring issue specifically, but that is even more less likely. I'd start with the switch
    life is good.
