what's so great about LSD's?
LSD advantages?
With the stock open differential, the wheel that has the least resistance gets the power... if one wheel is on ice, and the other wheel is on asphalt, the one on ice will spin... and you'll go nowhere.
LSD makes power go to both wheels (essentially... there are different types that do different things, but that's the idea)
It helps greatly in cornering, where one wheel can be unweighted (the outside wheel in a hard corner has less resistance... you don't want just that spinning!)
It helps greatly in acceleration from a stop, so you don't "peg leg"... as in lose traction and do a one-wheel burnout.
It helps when doing a burnout at the drag strip, so you can properly clean and heat both tires, not just one.
non-LSD ftl.
Originally posted by led_fut View PostDon't you mean the inside wheel? That's the problem that I have. Inside wheel has no weight on it, spins like crazy. Especially when its wet. Certain roads I can slap into second quickly and just spin for hours.
non-LSD ftl.
