ESP.net CB 90-93 Accord 2/3/4 Point Solid Strut Bars !!!
    www.ExplicitSpeedPerformance.net
    Explicit Speed Performance
    Email: ExplicitSpeed360@aol.com
    AIM: ExplicitSpeed360
    Phone: 1-360-866-8530 Monday-Saturday 10am-5pm
    Ask for John
    We, Explicit Speed Performance also fabricate custom strut bars for the Honda/Acura applications below. Our pieces are stronger than any other products out there. They will also be at an affordable price. They will help your car both on and off the track. Unibody cars have shock tower flex both in the front and rear. These strut bars will stiffen up your front and rear and will add strength to your chassis. They offer better handling and will help eliminate shock tower flex. All of our products are hand made and are high end quality. They are made from flat 3/16" and square 1" x .095" mild steel. They come with with a semi gloss black powder coated finish. For additional cost we have 150 other powder coating colors to choose from. Inquire for pricing on additonal color cost.
    Toss out your flimsy aluminum strut bars (Ebay) with joints. Having a joint causes a weak point. Solid Strut Bars are much more functionable. Our Steel bars are 2-3 times stronger then aluminum bars which means our bars are much more functionable. Insructions are included. 2/3 Point Front Upper Strut Bars will clear H/F swaps. You can also keep your fuse box in the stock location. 3 Point Front Upper Strut Bar requires you take off the windshield washer plastic to install the back plate of the 3rd Point bracket because the stock firewall has no previsions. As well as drilling 3 holes into the firewall for the prevision. 2/4 Point Rear Upper Strut Bars require the plastic/carpet side lining to be notched, function first! 4 Point Rear Upper Strut Bar can be used with the space saver tire but not a Full Size Spare. It also uses 2 bolts on each side of the frame on the back 2 points to create the best function 4 Point. Installing the 4 Point Rear Upper Strut Bar is simple as bolting it up marking the holes, unbolt it, drilling holes into chassis for the rear 2 pt's and bolting it up with our supplied hardware. All our products come with step by step detailed instructions and hardware if needed Grade 8 or 10.9
    We also have over 150 powder coat colors to choose from may cost extra depending on the color and may take a lil longer. Remember we always offer Packaged Deal Discounts on any 2 or more purchases made at once! Hit us up, let us know what you have to work with!
    CB 90-93 Accord ABS and NoN ABS chassis:
    2 Point Front Upper Strut Bar
    $139 shipped US
    $199 shipped US
    2 Point Rear Upper Strut Bar
    $129 shipped US
    $349 shipped US Large Box!
    2 Point Rear Lower
    $99 shipped US
    Pictured below is the CB 3 Point Front Upper, 2 Point Rear Upper and 2 Point Rear Lower:
    CB 4 Point Rear Upper:
    CB 3 Point Front Upper: Bright Red:
    Here is some pictures to show plenty of clearance with the H series swap in the CB with Our 3 Point Front Upper...
    CB 90-93 Accord 4 Point Rear Upper Strut Bar Installed:
    Sobeman81 feedback:
    Curiousity fullfilled:
    ^^^^the sign of a great business. I filled a whole bag with the paper used to wrap everything lol. Yes, i'm keeping the environment in mind and using the bag meant for recycling.
    installed. One hole was slightly off. Using my genius mind, i just moved the ratchet around a bit while turning it and BAM! done.
    I didn't get the 4 point because at that time it wasn't definite if it would be made or not. So i just got the 2 point.
    90AccordLXGuy Feedback:
    Put my bars in about a week ago
    Handles much better, not as much body roll anymore. Definitely a good piece!
      We ESP were mentioned again in the recent Feb/March 2010 Honda Tuning Magazine Issue on a beautifully modded 95 Honda Accord for our ESP CD Accord Motor Mount.
      Click to enlarge and read:
