Is there any other way to take a spring out without a spring compresser, I already know whats the danger comes through it. I take all my safely percaution very serious but today I wanted to go unsafe&ghetto in a rush because I dont want to rent a spring compresser & dont have cash at this moment. Is there any other way taking out the spring without using a spring compresser, Im not running oem springs so it has less tension on the spring.
Whats the other way taking out a spring
You could get someone heavy to put weight on the spring, compressing it a bit, then tie it securely with some very strong rope or wire. Then aim the nut away from you (into a trash can with a blanket stuffed into it) while you loosen it.
This is still a VERY VERY VERY bad idea. If the nut ricochets and hits you in the eye, goodbye eye. If the spring comes loose and bounces up, it will shatter bones... most likely in your face. If renting a spring compressor is too expensive and time consuming for you, a trip to the hospital is probably much more so!
Honestly, just go to Autozone (or something similar) and rent the compressor. You're in So-Cal... there has to be one within 10 minutes of you. Most places will let you rent it for free, with a refundable $40 deposit. Borrow $40, get the compressor, use it, return it, get the $40 back, and return that to the person you borrowed it from.
Yeah, it's really not worth the risk.
The first time I did my suspension, I did exactly what I suggested in my first reply... it was the very first thing I ever did to my car, and I followed my friend's suggestion. He was coming from 2 hours away to sell me the stuff and help install it, and the autoparts store down the street didn't have a compressor (they were closing... being changed to an Autozone...)
I changed a blown strut myself without a compressor as well... also managed to do it without getting hurt.
It was dumb. I was lucky. I don't want to see anyone get hurt because they weren't as lucky as me!
