gauges??
    gauges??
    i have a 92 accord and would like to install two of my gauges which are.. oil pressure and oil tempature, but dont know where the wires go to?? any help anyone
    Search and you will find
    Oil pressure gauge, to aftermarket sender unit if it's digital opg, 1/4" or 1/8" npt fitting can't remember off the top of my head, to oil pressure sending unit on block. Near oil filter? also can't remember location it's been a while since I've done one on a CB. Red power, Black ground, illumination is ?, and the other is signal. What type of gauges are they? Mine were Autometer, so it came with a little sending unit and opg was easy.
    life is good.
      they autometer too
        the oil sender is above the oil filter.. not sure on the temp i think it`s on the thermostat housing for the water
          for the oil presure, glowshift gauges have this kit that looks like the accord oil cooler. it goes between the filter and block. i much rather use that than the fiting on the oil presure sensor.
          as for the water temp, i believe the sensor is under the distributor,,,,
