Oxygen Sensor NTK/NGK/DENSO
    I read somewhere there's a special socket you have to use to remove the 02 sensor. Is this true?
      yes and no... special sockets are out there... basically a 22mm deep socket w/ a slot in the side for the wires... most of the time, just a simple 22mm or 7/8in wrench will do the job... spraying a little penetrating lube on the sensor about an hour before u remove it will help greatly as well...
      91 EX Coupe 5 Speed
      My Ride Thread
      ASE Certified Master Tech Since 2005
      That's like watching a guy stick his head up his own ass. Impressive... but why?
      Bought From: Quakerjoe , MikeW
        Originally posted by helidaddy View Post
        What O2 conversion are you referring to? I need to think about replacing mine also and I don't want to spend too much if I can help it. I just got this car (1991 SE) with 300,000 on it and I don't know if it's orig or not
        which model do you have?
        i actually have a bosch universal and been running it for 5 years. couple months ago ive developed a hesistation issue from a cold start. i need to change it or test it at least.
          Very few people have actually had luck with the Bosch sensors.
            i still do not understand where people are getting the whole 'bosch sensors need wiring adjustments' from... the one i bought from autozone (it was last minute and all they had) clipped right into my original connector and has worked just fine since. i'm not defending the brand, i hate their stuff too but i just don't know where people keep hearing this.
            90 ACCORD EX..<-- MR thread
              You are one of them.
              Bosch sensors are not wired correctly for our cars. There is (or at least was) a set of instructions on the Bosch website, showing you how to alter the sensor to work properly for our cars. THAT is where "people" are getting this.
              You have your own limited experience. I got my information directly from the manufacturer.
                did you seriously just quote yourself?
                  Yes, responding to the person that quoted above me, repeating what I had said before him... because he obviously felt the need to say "It worked fine for me!"... Yes, he is one of the rare few that it worked for. That, or he doesn't know how to tell when his car isn't running properly (maybe he thinks 20mpg is good? )
                  It was not an error.
                    you know you coulda just used the multiple quote setup and it would be a lot more efficient.
                      3am... 14 hours of work, and about a gallon of beer... The words make sense. What more do you want?
                        yea im just screwing with you
                          I'm confused... are you saying that few people have had bad luck with Bosch BEFORE or AFTER the alteration procedure. Does it even matter though... I mean do you still recommend I go with NTK or Denso?
                            cool, thanks. To save some cash I'm just gonna pull the good 02 sensor from my parts car and put it in mine.
                            Honda wants $250 for an 02 sensor. WTF!
                              50 dollar denso from rockauto.com will take care of you.
                                Well anybody have part numbers for Denso offhand? Denso's website doesn't give a part number for our cars... which I find hard to believe since there are so many of them still alive. NGK only lists a universal (part number 29415) but I'm looking to plug and play. My original is an NGK. 1991 SE
