motor from a 95 in a 91?
    so i was lookin on craigslist and found a motor from a 95 accord its a f22 2.2 single cam pretty sure it will work just wanting to make sure.
    it will fit its the same as the f22b vtec motor swap(in the swap section).but ur motor is better than that motor and u would be down grading.unless u need the motor as an replace ment motor for a daliy driver knock ur socks off and u have to get the ecu.also make sur its obd1.
    my new turbo build
      yes. Depending if it is the vtec engine you might have to do a little wiring. Other then that the mounts and everything will work for you.
