speedo is not working after swap
    i got a 93 accord lx with a h22 , i used the f22 harness and no check eng. light but my mph does not work the sensor is good . i followed the guide in the wire swap in cb7tunner , i am running the h22 dizzy and noticed theres one wire not used on the dizzy as well as on the coil , (they said dont worry about it) i am now my speedo is not working???? please some help
    they talk about a black wire, org. wire. yellow? wtf my accord has green/white, yellow/white, white/black!!!!!!!!
      IMO the dizzy is not connected to your speedo,VSS does..how do u know it still works?
        tested vss off the ground and rolled tire, the sensor is fluxing but i do not have a 12v anywhere on the plug? only 5.687 volts? ive look every where ,say the wire colors what they r but my colors r diff. ? my colors r green/white, blk/white,yellow/white???????
          does the CEL lights on?
            no check eng. light?
              need to know the colors for my wiring? anybody why is it diff. from 94? i have hemls man. colors dont match up
                id help but i left my manual at home. you need that 12v reference. that 5.67 might be the signal voltage, is that the one fluctuacting?
                  must be i used a 94 man. they said that connector b is 12 volt ? there was only 5.67 so i ran a 12 volt to sensor !!!!!!!!!!!!!!!!!!!! yea blew my ecu !!!it was signal wire back to ecu !!!! at lest i have more ecu's wont be doing that agin
