Suspension
    Suspension
    When lowering the car do you suggest get alignment? My tires are chew up inside from the tire. I heard theres no need camber kit, everyone telling adjust the toe to 0 as possible.
    My car is lower 2.25/2.25 running on sprint springs.
    Ummmmmmmmmmmmmm......
    YES!!
      Camber does eat away at your tires, but not nearly as quickly as toe and caster.
        b4 when i ran my car with no alignment and a 2" drop i went through front tires evry two months.
        i got an alignment and set my toe at 0 with no camber kit and ive had my tires now for the past 10 months.
        GET AN ALIGNMENT!
        alone in this game . ::My Ride My Way::
          Im going to get my alignment done today.
          Thanks JoshM, Tear2wo
            Alignment is not a suggestion. It is a mandatory thing whenever you touch your suspension. If your tires are already chewed up, then you need to replace them as well. An alignment now isn't going to give you your tires back.
            A camber kit is necessary if you don't want to wear out the inside. As JoshM said, toe will kill your tires faster than camber, but they are independent of each other... so fixing toe won't correct camber-related wear. Bad toe and negative camber will VERY quickly destroy the insides of your tires. I've gone through tires in 6,000 miles due to this (my camber kit broke, never realigned... stupid)
            Caster really isn't an issue on our cars. It really isn't adjustable to any significant amount. It isn't really a factor in tire wear as far as we're concerned.
