doch f22b or h22a swap?
    right now i just want to swap one of those motors in. but my final plan is to go turbo safely on stock internals. so my question is which motor would be better suited for that? which will make more power in the end and still be a good daily driver. tnaks
    Honestly... I wounldn't expect any old stock Honda motor to be safe as a daily driver when boosted.
    It depends on your tuner. The H22 has higher compression, which gives you a smaller margin of error when tuning.
    Your best bet is to learn a bit more about turbo. Then you can make your own decision. Otherwise, some idiot 16 year old kid with 10,000 posts on here is going to tell you what he thinks would be good... you're going to listen to him, and you're going to find yourself out a few grand, with a broken car on your hands.
      thanks for the input.. i am pretty familiar with turbo motors i owned a few dsm b4 this is just my first honda and im not sure how well they hold boost. but ill do sum research and see wat im goin to do..... thanks
        I assume your experience is with the 4G63T, right?
        Honda motors are a bit different. They were never built for boost, so one bad tune and you have yourself an aluminum paperweight. The higher the compression, the greater the chances of detonation on a tune that isn't perfect.
        Honestly, the F22A has amazing potential. If there's nothing wrong with your motor, boost that. It may not look as fancy as a DOHC motor, but it's designed very well (Bisi Ezerioha, Bisimoto here on the board, is a pro drag racer... he holds world records... and he uses the F22A)
          The F22 is a great motor to boost. My favorite H motor is the H23. Both are good for a snail though, as long as they're not too tired.
          life is good.
            yeah i had a 4g63t... as for my f22 timing belt popped on the the highway and i bent some valves so my car is sittin with no motor in it.... i've been lukin at f22 built for turbo nd they actually make gud power. im still up in the air with which motor to go with. but i have until spring to decide........
              how long do u think an h23 will last with stock internals?
                It depends on the condition of the motor, the quality of the tune, the parts used, how much boost you run, and how you drive and maintain it.
                In other words... it's impossible to say.
                If you want to guarantee that your turbo engine lasts for a good long time, buy yourself a new Mazdaspeed 3 with an extended warranty.
                  an f22b will be harder to rebuild due to parts. id opt for that engine though because it is a lot cheaper.
                    its funny that you said that cuz i just test drove an rx-8 the other day.. if i did get a mazda it would have to be a rotary
                      not in my case h22a is $800 nd the F22 is $900.....
                        i get it.... a turbo honda motor is a hit or miss unless you built it
                          Even then, it's hit or miss. Chances are good that it will last if you know what you're doing... but when you're replacing every part, the chance increases that something could fail with every part you touch.
                          Even a built motor can blow. You CAN have a perfectly reliable turbo Honda, but it's best not to expect to rely on it.
                            I know I am one of the current exceptions to the rule, but if you use quality parts, quality labor, and get a quality tune, you can have a reliable dd turbo cb7, even with a dsm setup.
                            If you do want a relibale turbo dd cb7, like I said, use quality parts, honda gaskets, seals, real MHI turbo, etc, etc, and work with someone who is a good mechanic. Get a good, safe tune on it, and drive the pants off of it.
                            But, then again, you could so all of this and have terrible luck. Luck is a key factor too!
                            But, my vote is f22b dohc or f22a boosted if you really want to boost it. Keep up with maintenance and all should be well, so long as you don't rev at everything you see and don't try and race everything ever all the time.
                              wat setup r u running?
