Gas Milage/ whirr-ing noise?!
    92 ex, 212xxx
    K, two problems:
    1 - CEL, Brake, and ABS lights are on.. and sometimes when i stop i get this whirr-ing noise from my back drivers side wheel well area. I have to drive back to Columbus from Cininnati today..
    2 - I just filled my tank, and ive been drivin mostly highway, round 70 mph.. tank is almost empty, and i have 270 or so miles. Wtf?
    Plz help me!
    92' Ex - Needs work, but hey! It runs safely
    91' Lx -Car vs IDIOT.. R.I.P.
    RIP 92' Lx... Car vs Concrete.. Car lost.
    Originally posted by Aries1911 View Post
    92 ex, 212xxx
    K, two problems:
    Plz help me!
    For:
    1. Check your brake fluid level. I know that once I ran low, due to a leaking line and my BRAKE light came on and stayed on. If the plunger senses a low fluid level, it'll trigger this light to come on and may also trigger the ABS light to come on.
    2. When was the last time you replaced you fuel filter? It could be clogged if you haven't done it ever. Also it won't hurt to do a minor tune up if you haven't done that either (plugs, plug wires, distributor cap, and rotor). check your Air filter and tire pressure too, make sure thats good. Make sure you have no sticking calipers...that can cause the ABS light to come on if its dragging on the brake rotor and overheating it. That "whirring" noise could also be a wheel bearing going out, they tend to humm so its a possibility.
      but the whirring noise could also very well be worn brake pads grinding on the rotor to i know ive experienced it from the idiot when i first bought my car.
      You don't have to like what he did, but I would hope that you can appreciate the time, money and love that went in to the build. If you can't, you're not really an enthusiast, just another dumb kid with a car.-visualpoet
      Money and Knowledge are never in the same sentence, because people with Money think they know it all, but people with knowledge, know better.-ragingasian
        The Noise could be the Fuel Pump I know on the 91-92 crossover year (92 with some 91 parts) some of the aftermarket fuel pumps don't fit quite right. The bottom of the pump where the screen filter goes sits at an angle and if its hitting the plastic tray it will make noise. When I replaced one last year you could hear it driving around town all the time and it was really noticeable at idle. Not sure if its a sign of a pump going bad but I guess in theory it could be working the pump harder if the fuel filter was clogged.
        H22A, Short Ram, AEM Uego, Chipped P28 with Crome, A/C Delete, Rear disc conversion. (Front Tein Basic Coilovers, H&R springs 1.7/1.5, and Fog lights waiting to be installed.)
          im pretty sure my back brakes are drum... arent they? Maybe i should get one of those fuel cleaner things from the gas station n try that? or take it back to firestone to have it checked out again?
          Losiracer - i myself havent replaced it.. bought the car a year ago.. probably safe to assume it hasnt been done. Is that expensive? My college student budget cant handle much lol
          Paging - I dont hear anything at idle.. its normally when i let off the brake n start rolling that it starts up.. i think it stops once up to speed, but im not sure.
