what is the best swap in an 93se for street and strip
motor swap
This topic is closed.
Originally posted by 93 accord se View Postwhat is the best swap in an 93se for street and strip
The motors you can get for your CB7 that drop right in are: (some might need some minor mod)
-F20bx DOHC Vtec
-F20a SI DOHC non-vtec
-F20a SOHC non-Vtec
-F22ax SOHC non-Vtec (stock from factory) the f22a6 is better.
-JDM f22b DOCH non-vtec
-JDM H22a DOHC Vtec
-H22a1, 4, 7 DOCH Vtec
-JDM H23a DOHC Vtec
-H23a1 DOHC non-Vtec
With custom mods and motor mounts:
-K20 DOHC Vtec
-K24 DOHC Vtec
And RWD but it to expensive and pain in the ass:
-F20c DOHC Vtec
-F22c1 DOHC Vtec
everyone goes for the h22. simply the same with v-tec correct?
can u simply swap the head. for cams?
or is there a bottom end that can be used and more powerful keeping the top.
i dont see the point unless you have blown the engine.
does the stock engine have v-tec?
i thought it would be better single cam if boosting and lots of power....
h22 has an additional 50hp?
just want clarification.
VTEC, not v-tec.
Switching the head will not give much of a gain. The bottom end is important as well. The compression is higher, the stroke is shoter, and the materials are different.
The F22A (stock Accord engine) does not have VTEC. I suggest you Google VTEC and read about how it works. It's good to know.
The number of cams really doesn't matter in power production. It makes adjusting cam timing easier, but other than that, the SOHC valvetrain has less mass, and better packaging.
The H22 makes anywhere from 190hp to 220hp, depending on the version. The F22A makes 125hp to 140hp.
Jdm H22 Doesnt Bolt Into My 1992 Honda Accord
thank u guess in advance ...... i have a 1992 lx honda accord, and i brought a jdm h22a complete swap ,and they say the jdm h22 will bolt right in but mines doesnt ..the tranny mount is to long and it is throwing the engine off it news to go up and over to the right i cant get the driverside mount in nor the tranny mount.. CAN ANYONE TELL ME WHAT I NEED TO DO A
