Fuel pump replacement
    Ok well im 90% sure my fuel pump is on its way out so i need to replace it...
    How hard is this going to be?
    I've completed a motor swap so its not like i have no mechanical skills i just need to know how much time and stuff is going to have to go into this
    Click it.... You know you wanna
    Bought from:Joshy,H22WAGON93, nho93accord,90accordLXGUY,phantomCB7,Tommi
    No words of wisdom for the dark road ahead lol?
      its easy
      drop the straps. pull the tank down. disconect the hoses and wires. pull it out. unbolt the the fuel pump it out
      miss my turbo cb7
        Really? nothings in the way?
          You will need to drop the tank. My MA Cb has a good amount of rust to deal with so the job was sort of a pain. I would defiantly recommend that you NOT do this outside. Its a pain dealing with 17 year old lines that may leak after attempting to disconnect them. I am a tech and I wouldn't attempt this job without a lift and a trans jack to raise and lower the tank. Not to mention that it is gasoline which is dangerous, and also is a terrible aftershave that just sort of lingers for a while. Let the pros deal with this crappy job its not going to be fun.
          My CB7 http://www.cb7tuner.com/vbb/showthre...hlight=phalpin
            no
            miss my turbo cb7
              Thanks but i refuse to pay over 500 dollars in labor for a couple hour job... if i swaped my own motor i think i can manage a fuel pump and tank drop
                Originally posted by quickangel93 View Post
                no
                Sweet so a few hours and the driveway and the CB would be golden...
                Any thing i should do while i have it out?
                replace lines or anything?
                  Oh and if you do attempt make sure the car has less than a quarter of a tank of fuel. The more fuel in the tank the heavier it will be.
                    dont you mean i did the swap lol
                    Click Here To Check Out My Ride
                    http://www.cb7tuner.com/vbb/showthread.php?t=137030
                      Yeah i would assume less fuel would make it a bit easier
                        You helped a lot I could have gotten it done just would have taken forever..
                        And i knew nothing about the car at the time lol
                          I could have you just sped up the process with getting it in and out because you had done it before
                          lol i know just kidden around
                            Haha yeah so ill have to not fill up the car on payday and then the Saturday after ill be doing a fuel pump.
                              yea run that bitch dry. ever gallon in there is extra weight. and when u got like 6 gallons in there. it feels like 600 pounds
                              miss my turbo cb7
