Its only purpose is to make sure the gauge reads correctly?
Fuel Sending Unit
This was copied and pasted from another site. Hope it helps.
"The fuel sending unit is used to measure the level of fuel in the tank. This is located in the fuel tank of your vehicle and it consists of a float which is usually made of foam and is connected to a metal rod. The end of this rod is mounted to a variable resistor, an electrical device that can resist the flow of electricity. The variable resistor has a strip of resistive material connected on one side to the ground and a wiper slides along this to conduct current from the gauge to the resistor. How close or how far the wiper is to the strip will determine the amount of resistance. There is a small resistance if the wiper is close to the grounded side of the strip and if it is at the other end of the strip, the resistance is large. When the resistance is small, the float is near the top of the tank because there is a large amount of current that passes through the sending unit to the fuel gauge. If the level in the tank drops, the float also sinks. The wiper then moves as the resistance increases and the amount of current sent back to the gauge decreases."
