Do I need to take off the hub in order to take off the c/v joint, and if so, what is the diameter of the hub nut? Standard or Metric is fine, I'm asking b/c I do not have a socket that fits it, biggest I have is a 28mm and its way too small, this is the stock hub if that helps any...Thanks in advance.
C/V Joint Replacement Help!
what i did to get leverage was just use a 1/2 inch breaker bar and find a 5 ft. galvanized steel pipe at lowes for like 10 bucks and slip it over the breaker bar.
Originally posted by 92jdm View Postthats acually your axle nut. and you do have to remove that to take your axle off.
its a 36mm socket.
OP he's right, you have to take the Nut off to get the CV out reguardless, You don't have to remove the entire hub though.
You can usually just take off the top balljoint, hub nut and lower shock fork to give enough room to slip the CV out.
My 5.7 LS1 Holden Ute
i do it basically the same.
i like to take off the lower BJ nut and the tie rod nut. then the lower fork bolt.
Originally posted by 91_CB7_Sedan View PostDo I need to take off the hub in order to take off the c/v joint, and if so, what is the diameter of the hub nut? Standard or Metric is fine, I'm asking b/c I do not have a socket that fits it, biggest I have is a 28mm and its way too small, this is the stock hub if that helps any...Thanks in advance.
also. since i have rims, i had to put the spare wheel on and lower down the car on the grown to loosen the 36mm hub nut.
You can get that 36mm socket (for the front axle nut) at Autozone as a loaner and return it after the job is done.
helps if you have a small-tipped (1/4 inch or 3/8 inch) cold chisel to help when unstaking the axle nut. one trick is to slightly back off the axle nut, partially unbending the staked portion, then turn the nut back to its starting position. Now there will be more space to get the chisel in & under to finish unstaking the nut.Last edited by batever; 12-30-2009, 12:31 PM.
