so i took the car for an oil change, the person whom i took it to said that there is an oil leak from the rear seal and the front seal. My question is, is it a real hard and expensive job to get it replaced? what kind of ball park figure i am looking at? or can it be done by myself?
Rear and front engine seal leak
If he's talking about the rear main seal, the transmission, clutch and flywheel have to come off to get to it. If you are not mechanically sound then doing it yourself might not be the best idea. The front seal is fairly easy, you just take off the pulley belts, remove the crank pulley, pull the old seal out and put on the new one.
They are easy to do, even easier with the motor out of the car, to change the front main seal you have to remove tranny,clutch and flywheel. To remove the rear you have to remove the pulley, timing cover,crank gear. You'll need a special picking tool to get the seals out also while you're at it might as well do the balancer shaft seal. As or the cost of seals I got them for $16 for all seals.
I paid someone to do this on my eclipse because I did not have another car to go to work in and didn't have the time or tools either. I bought a kit with all of the gasktes for the top end and everything else that would be taken out and parts and labor all together cost me around 375 to have it done.
Originally posted by Brandoncb7 View PostI paid someone to do this on my eclipse because I did not have another car to go to work in and didn't have the time or tools either. I bought a kit with all of the gasktes for the top end and everything else that would be taken out and parts and labor all together cost me around 375 to have it done.
thanks man, thats what i was looking for. Oh well, another whole pay cheque goes toward my car
In btw, here is the stupid thing.. the car oil change was done last year.. plus i have been using it since last 4 months.. and the oil was a little bit low when i took it to the service center.. so i mean, does this work need very urgent attention?
thanks everyone for your replies!
Originally posted by masarwar View Postthanks man, thats what i was looking for. Oh well, another whole pay cheque goes toward my car
Originally posted by Brandoncb7 View PostYeah you need to get it taken of as soon as you can afford it. Until that can happen though just keep a close eye on your oil level. Pretty much before you leave the house with it you need to check the oil and it probably wouldn't hurt to keep a quart or two with you in the car just in case. Eventually it's going to result in catastrophe though.
$400, honestly, is a very fair price. I HATE taking my transmission off! I'd gladly pay that to have it done!
Really, though... the job isn't all that difficult. It's time consuming, and there's a lot involved... but there's nothing really hard about it. It all makes sense the way things are put together. As long as you mark all your bolts, torque everything properly, and take your time, it's not something you can't do yourself. If you have another car to drive, and a place to work, I'd say give it a shot.
As for mounts... you have options. You could pay for new aftermarket mounts, which are ok. You could fill your old mounts with polyurethane, which will make them stiffer. It will help put power to the ground, but you'll get increased vibration inside the car (if this car is a "nice" car, and not a performance toy, you might not want that). Or you could invest in the ESP mount kit. All brand new mounts with urethane inserts. Very high quality stuff, and ESP's prices are reasonable. They're normal tuner guys like us, not some big-name corporation that doesn't understand us!
It's funny how the front and rear main seals are on the sides of the engine. Old longitudinally-mounted RWD terminology there!
Originally posted by masarwar View PostThanks man, i went to the mechanic, he gave me an estimate of 400$.. i will prolly get done all the seals and also all the mounts as well, while it is out. Is there anything else you guys can recommend?
Originally posted by deevergote View Post$400, honestly, is a very fair price. I HATE taking my transmission off! I'd gladly pay that to have it done!
thanks bro, i will look into different kind of mounts that are available here, it is my daily driver though so i dont know if polyurethane would be a good idea. But i will check it out, and thanks once again!
Originally posted by Brandoncb7 View PostJust look at everything that will be taken apart and replace all of the seals for everything along with anything else you can think of. If you're looking at swapping in a different clutch in the near future you might as well go ahead and get it now. The labor costs will be the same wether your mechanic puts in new parts or the old ones so you might want to look into what you can upgrade while everything is apart.
