Finally got my 92 Accord w/h22a1 running right, but I just found out that both fans are dead. I hooked them up straight to the battery and nothing. So I'm looking at getting 2 slim fans (maybe 12") but I saw that they can be wired to either push or pull. I don't know whether I want them to push or pull, so if someone can help me out, that would be great. Tried searching through different threads and couldn't find the answer. Thanks everyone...
Cooling Fan Push or Pull
from my point of view
you want to know whats better?
to mount the fans behind the rad(pull)
or to mount the before the rad (push)
if you can get them behind, go ahead (clean look), be careful on the type of fan you choose just because is a slim fan does and doesnt mean is better
look at the fans CFM b4 buying
also dont have them running all the time, you'll over spin them after 50mph
id hook one up like the oem one is, and one on a switch so if needed you can turn it on or off.
smoke tires, not drugs.
Originally posted by Teddy View Postif you mount the fan on the inside [stock location ]it`s pulling ..if you mount it behind the grill on the radiator it`s pushing .. hope this helps...i like the stock location if you have the room
Originally posted by visualpoet View PostIt doesn't matter where you mount them, it's which polarity you wire the motor that decides whether it pushes or pulls.
a fan that used for pulling air, if you invert polarities it might push air an a 360 degree all around the base instead of forward
Originally posted by PR CB7 View Postit depends on the way the wings are on the actual fan
that type of fan is only good for pulling, it sucks on reverse polarity
unlike an OEM one
Now, if the motor isn't designed to run as efficiently with the polarity reversed, I could maybe see it, but the fans the OP was asking about are designed to run either way, hence the question about wiring them to push or pull.
i tested w a digital temp gauge,
the same fan as you see in the picture
in a pulling position it took 1.45 seconds to shut off (OEM FAN SWITCH)
in a pushing position it took 2.94 seconds to shut off
wo no condenser fan pushing again 2.80 seconds to shut of
OEM fan, OEM location took 1.20 seconds
maybe i tested it wrong, but thats what i base my results with
Woah, its getting pretty technical in here. lol.. One more question.. I have an aftermarket aluminum radiator, but not one of the racing ones like Koyo or Mushimoto, mine has the plastic end tanks. My question is, are 2 small fans completely necessary or will 1 big one suffice and how much CFM should I look for if I go with 1 or 2? This car, is going to be a daily driver and visit the track only a couple times a year.
Originally posted by NinJa_FLiP View PostWoah, its getting pretty technical in here. lol.. One more question.. I have an aftermarket aluminum radiator, but not one of the racing ones like Koyo or Mushimoto, mine has the plastic end tanks. My question is, are 2 small fans completely necessary or will 1 big one suffice and how much CFM should I look for if I go with 1 or 2? This car, is going to be a daily driver and visit the track only a couple times a year.
still 2 small fans should suffice, fans, bigger rad, ETC your thermostat is what controls your temp, and fans are mainly for idling or standing still, once you get rolling they'll shut off
