power steering fluid leaking
    okay well since i bought my wagon (f22b1 engine auto) my car has been leaking ps fluid on the passenger side. my whole driveway is messed up and my mom finally got fed up
    any way to fix the leak besides replacing the rack. im kind of on a budget.
    thanks evry1
    alone in this game . ::My Ride My Way::
    Are you for certain it's the rack leaking on the passenger side?
    Someone is going to tell you to replace the seals and the boot but in reality it'll probably be cheaper in the long run to replace the rack now and have to do an alignment only once. Could you park on the street instead of on your mothers driveway you fix the problem?
      yea i cant park in the street. i live in a gated community and cars get towed after 2am if you leave them on the street.
      how hard is it to replace the rack and where can i get one ?
        it doesn't look terribly hard but it's best for you to have a set of flare nut wrenches for all the fluid lines.
        Theres a DIY that someone made with lots of pretty pictures. i'd image you could get them at NAPA, maybe Autozone and definitly at Honda.
          car-part.com put in your info of car and zip code it will bring up a list of your local J.Y.s in your area with the price and will list them from cheapest to most expensive..... i just bought one last month for 75-
            okay i jus read the diy. seems like a pain in the ass. the diy says it should take between 3-6 hours so itll take me about 2 or 3 days thanks guys for your help .
            im going to be doing an engine swap soon so will it be better to replace it with the engine out ? or will it be the same thing
              Either way you'll be on your back unless you have access to a lift.
