ok so i went to the junkyard the other day i found tanabe exhaust with the cat cut off but grabbed the rest. so basically i have the resignator back. but it came off a ek coupe. how much of the exhaust can i use on my cb7 im hoping to be able to use the straight peices then have a shop make the rest.
huge question
Originally posted by deevergote View PostAnd it's resonator, not resignator.
If the muffler+resonator are of a good size, 2.25 or 2.5" then sure, hack em off and take them to an exhaust shop.. Piping and labour isn't expensive, mufflers are.Built & Boosted.
There really won't be enough of the piping that's the right size to make a difference. Hack off the muffler, get a shop to custom-make you piping, and sell the pipe from the EG to someone with an EG.
And are you sure it's 2.5"? 2.5" on an EG would be serious overkill, unless the car was running a big engine, had heavy mods, or was turbo. Or he was just a ricer... which is likely.
Originally posted by deevergote View PostThere really won't be enough of the piping that's the right size to make a difference. Hack off the muffler, get a shop to custom-make you piping, and sell the pipe from the EG to someone with an EG.
The muffler is the only piece that is going to work. Luckily for you, this is usually the most expensive piece at a shop.
Originally posted by deevergote View PostI missed that it was Tanabe. If that's the case, it's probably no bigger than 60mm. Most Japanese exhaust systems are that size. For a smaller engine, it should be less.
Tanabe is decent. Not really a ricer brand.
