wtb new spark plug in need of help
This topic is closed.
    i have a90 accord with h22 swap.and the gt cf hood when it rain and snow. water get in the plug hole i have bosh plug now and in not happy with it. it think the plug are bad so what kind of spark plug wiresi should get. i saw some ebay 10.2mm plug. or what are u guy runing . in tired of talking water out the plug hole aredy time it rain or snow please help me out i know my grammer is bab and my spelling too
    NGK all day!
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      im looking for perfomance wire set. in not to worry about the money
        I don't think new plugs or wires are going to change anything in regards to the rain getting through the hood and into the VC tube. (I think that's what you're saying.) Seems to me that you have hood issues rather than spark plug issues. If you're spending the money anyway, get NGK as previously mentioned.
          NGK wires. NGK plugs. If water is getting into your engine because of your hood... replace your hood. Or you'll be replacing your engine.
            Shouldn't the plug wire boot prevent anything from entering the holes since they should seal to the valve cover?
            Originally posted by chessboxer
            We know these are good cars, but for some reason, all the world wants are freaking civics and tegs. Bleck.
            Bought From: Slammed4thGen TypeG x2DeevergoteBillKisme
              yes it is the VC tube. that were the water collecting. i just spent 600 for this hood. they is anything else i can do with out replace the hood. i did aredy i tape the vent shut. i was thinking about firber glass it shut.
              i also have the plug cover on it so have any idea? on this problem
                If you can seal the hood, then it should be fine. Just keep water from getting in there. You do not want water getting anywhere near your spark plugs. If it manages to get into a cylinder, you could hydrolock. That may be a longshot... but not worth the risk.
                  i thought the plug boot would stop the water to go in the hole?? i had a couple cb7 with the f22 i could clean the engine bay but the h22 i try late spring and water got in the hole
                    It should stop most of it, but you should still try to keep water off of it.
                      ngk wire are only7 or 8mm and they look oem. the ebay are 10.2mm i think what would be better? i one im looking right now are the nology or moroso one i know they are over $100
                      so here are my choice
                      ngk 7mm
                      ebay one 10.2mm
                      nology 9mm i beive
                      moroso 8 mm
                      i will be placing a order on tuesday night
                        NGK. Nothing else.
                          OEM style is all you need really. I believe those way over sized plug wires are just for looks
                          1992 Accord Wagon (RETIRED)
                            just loook im the kind of guy that wanna buy the best when i need to replace stuff im planning to have alest 300 hp at the wheel
                              sounds like cap a rotor time for you
                              only wires i'd buy, NGK or Accel.
                              NGK are cheaper and are sexy blue so the choice was easy.
                              wat?
