F22 oil leak behinf engine.
    I beginning to think it's the rear main seal the one that you have to remove the tranny to replace.
      Leak is at the back of the engine, in center where oil pressure sensor is and oil filter... it is about 20 santimetrs wide and goes from intake manifold to the bottom, yesterday i cleaned the engine, started, didn't see no leak, car was running about 30min. and engine was clean, rided 2 rings, about 5 kilometrs, watched still no leak, thouth that was over... today went otside, about a liter of oil on the ground, back off the engine in oil... can there be some crack on the block?
        could it be your oil pressure sending unit is lose above the oil filter
          i agree with boosted4door if not i would remove the engine or at least the im to get a better look on things
          h22a4+p2u5 trans+8000rpm= 135mph in 4 gear
            Wait so you changed the oil pressure sending unit huh? did you put teflon-tape on the threads to make a nice seal on it or did you just screw in the sensor by itself.
            You should really get us some pictures where you see the leak at so that we can help you a step further. Oil leaks are like chasing a ghost when you dont have 2 eyes or more to see for you. And when you take the pictures get some good light under there so we can see it clearly.
              Yep, teflon tape, did that... i allready bought another car with same engine for 200$... i think nice price... odometr is 325 kilometrs, but engine works nice... will change in some days...
                yea your better off with that cause that sounded real serious
