F22 oil leak behinf engine.
    I did many things, changed changed oil pressure sensor, changed rubber ring on heat exchenger, a'im so f_cked with this car, oil burns, and goes in to car... plz help, i didn't seen on pages this kind of problemm...
    only real hope, is to clean the engine off with a degreaser. That way you'll be able to "see" for sure where the leak is. This will take the guess work out and save you time and money instead of fixing what you think is the problem.
    Buy a $3.99 can of engine degreaser. Spray entire can on the engine where the oil is present. Let soak for 30mins. Spray off with water hose. Let it dry byitself, not by running engine. Then once dry start the car and now you can truly chase the oil leak from the problem source! Good luck.
      I tried... no help... oil goes all over the engine...
        How does it go all over the engine? If a leak is that bad... then perhaps the engine should just be replaced!
        Cleaning the oil off of the engine, running it briefly until it leaks again, and seeing where it's leaking from is the best way to figure out what you need to fix. If that won't help you locate the leak, or if there are numerous leaks... then a full replacement or rebuild might be the easiest solution.
          Oil filter on tight?
          Originally posted by chessboxer
          We know these are good cars, but for some reason, all the world wants are freaking civics and tegs. Bleck.
          Bought From: Slammed4thGen TypeG x2DeevergoteBillKisme
            Yep, oil filter tight... i will try to locate wherre from goes the leak( so f_cked, so depressed with this car.
              what bout valve cover gasket...?
                Originally posted by 4thgentuner View Post
                what bout oil pan gasket...?
                I would assume that if the oil pan was leaking, oil would be all over the ground, not the motor.
                  Valve cover gasket new. Changed allmost everything...
                    Do have an f22a6 equipped with an oil cooler? If yes then it's probably the oring for the oil cooler plate.
                      Yep, yesterday changed, it was in bad condition, but didn't help(
                        replace all the o-rings (retainers) of the engine specially the one between the engine and the transmission.
                          i don t no if this will help but my h22a4 it the bolts 4 the half shaft aint tight oil will leak out of there
                          h22a4+p2u5 trans+8000rpm= 135mph in 4 gear
                            the haft shaft bolt holes i mean
                              where does most of the oil appear to be coming from? Valve cover area? Timing belt covers? which Side of the engine? Crank pulley side or Distributor side?
                              What does the PCV system look like? Is it functional?
                              Time to stop guessing at the problem, try to find the area that seems to leak first and tell us where that is. Maybe we can help you eliminate some things before you change every o-ring and seal availible and then still have a leak.
