will a short shifter from a 94-97 accord fit on my cb7?
    theres a guy sellin a short shifter for a 94-97 accord, n i know that the suspension from that year fits cb7s so i thought that the short shifter might fit as well.
    am i correct?
    1992 Honda Accord Lx
    [/I][/I][/I]
    Yes, it will fit (though assuming so based on the suspension fitting makes no sense at all...)
    Short shifters often cause notchy shifting, though, and can result in transmission damage. I had one, and I put it back to stock because the shifting got so bad.
      not sure about that, but i have heard of people using oem prelude shifter for our CBs
        Which is why my OEM one is back in too.
        I had a custom welded (shortened length) Prelude shifter. Installation was as easy as taking the OEM one out.
          Josh, did you have the mounting point changed, or just the length of the lever? Shortening the lever does nothing for the actual throw... though it can change the feel a little bit.
            The linkage mounting point was raised about an inch from stock. Let me try to find a pic (although I don't think I have one)...
            Edit: No pics.
